Hoover SE264-80 – Module
  • #48577
    jackster
    Hi all, I have got the above model that is toally dead, I have got 240v to m/c so I am assuming module? I havehad a look at it and there are no dry joints etc, connections are fine.I dont do a lot of Hoover so any advice would be appreciated, part number would be nice to! Chears all in advance.
    #297026
    loopey
    Re: Hoover SE264-80 – Module
    hoover part number is 09200351 connect 31000830 thats a pre programed pcb , plug and play lol ..
    hth phil
    #297027
    jackster wrote:Hi all, I have got the above model that is toally dead, I have got 240v to m/c so I am assuming module?
    Don’t assume too much in that it could simply be that the door interlock is faulty? Do take a real close look at the surface mounted components of the module for damage of course and by all means. The 5 triacs especially need careful examination and can lead you direct to the source of the fault….perhaps?
    #297028
    jackster
    Thanks for the advice, after a bit of TLC on the pcb & connections I have got it running, however it is not playing ball completeley! It now stops after around 10 mins on each cycle except the boil wash were it is dead, doent want to know. I have checked the element isnt down to Earth, checked stat – A/OK. Door lock I replaced anyway, still the same??
    #297029
    Hot Valve? Timer dial jammed with coffee stains?…..just a thought or 3 😉
    #297030
    jackster
    I checked the hot valve, thats ok. I will check the timer for stains though.. thanks martin.
