Hoover Softwave 1100 washer/dryer
Home Forums Public Support Forums Spare Parts Help Hoover Softwave 1100 washer/dryer
Viewing 15 posts - 1 through 15 (of 18 total)
  • #7999
    I was wondering if anyone could help regarding the above washer/dryer. The small grey plastic bit on the door that goes into a hole in the machine to hold and lock the door has snapped and despite several glueing keeps coming off!
    Does anyone have any idea if I can buy the back part of the door with this bit of plastic on or even a new door
    Thanks in advance for any help!
    mcmikecort@aol.com
    #126333
    Re: Hoover Softwave 1100 washer/dryer
    No problem, just needs a new inner door trim to fix. Let us have the exact model number for getting the right part. Possibly available in our 😀 shop@
    Brilliant, i’ll get the part details tonight. How do I contact your shop? is it through here? (you’ll have to excuse my ignorance i’ve not used this site before)
    Cheers
    #126335
    Yes,
    Just on the left hand side of your screen!
    Dave_Conway
    The part you need isn’t inthe shop at the moment, I can easily add it though for you, let us have the model number and I’ll check it out for you 😀
    #126337
    The inner door trim doesnt saeem to have a full part number. I took it off and all it has is the Hoover logo and H2 -1 The actual front cover has a part number ofD37341-530 issue / MJ26529D H1. As I said initially, I only want whatever bit has the plastic clip that holds the door shut into the washer/dryer itself. Is that enough info or do you need more?
    #126338
    Dave_Conway
    Anonymous wrote:Is that enough info or do you need more?
    More please, it’s the model number of the washing machine we’re after rather than the part number for the door.
    The model should actaully be on the inner door frame, but it sounds like it’s either fallen off or been removed.
    It will also be on the back somewhere and in the user manual.
    #126339
    P/no 09077165 – about £8 from memory. The model number is on a label around the door opening and will start “A8—“. It’s also on a label on the side of the right side of the machine and a rating plate on the bottom rear. However, the part number is 99.99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} likely to be correct.
    Check, then contact spares@ukwhitegoods.com and it’ll get sorted out.
    Last one I promise!
    I cant find anything begining with “A8” but in the place you mentioned on the door opening, there is a number – “WS 11574500002”. On the right hand side of the machine there is a shortened version of this number “WS 115-001. Do either of these sound like the right number?
    #126341
    Dave_Conway
    Got the email thanks.
    #126342
    Dave_Conway
    The part is already in the shop@ 😆
    http://shop.ukwhitegoods.co.uk/Washing+ … Frame.html
    #126343
    can any one tell me which pipe it is that i need to take of to look for a blockage took the big black one of the drum and emptyed the water all over please help cheers wayne
    #126344
    Anonymous wrote:can any one tell me which pipe it is that i need to take of to look for a blockage took the big black one of the drum and emptyed the water all over please help cheers wayne
    Also check the pump itself is not blocked and is free to rotate!
    Hi I’ve also just suffered the same problem. I have model number
    A875470400374 on the machine. Can you please advise me if there’s a part of this?
    Thanks very much.
    #126346
    I take you are after a drain pump?
    http://shop.ukwhitegoods.co.uk/Washing+ … +Pump.html
    will take you there.
    Before spending your money you have checked for blockages?
