Home › Forums › Public Support Forums › Spare Parts Help › Hoover Softwave 1100 washer/dryer
- This topic has 17 replies, 4 voices, and was last updated 21 years, 1 month ago by
admin.
February 17, 2005 at 2:15 pm #7999
KeymasterI was wondering if anyone could help regarding the above washer/dryer. The small grey plastic bit on the door that goes into a hole in the machine to hold and lock the door has snapped and despite several glueing keeps coming off!
Does anyone have any idea if I can buy the back part of the door with this bit of plastic on or even a new door
Thanks in advance for any help!
February 17, 2005 at 2:20 pm #126333Martin
ParticipantRe: Hoover Softwave 1100 washer/dryer
No problem, just needs a new inner door trim to fix. Let us have the exact model number for getting the right part. Possibly available in our 😀 shop@
February 17, 2005 at 3:53 pm #126334admin
KeymasterRe: Hoover Softwave 1100 washer/dryer
Brilliant, i’ll get the part details tonight. How do I contact your shop? is it through here? (you’ll have to excuse my ignorance i’ve not used this site before)
Cheers
February 17, 2005 at 4:11 pm #126335Martin
Yes,
Just on the left hand side of your screen!
MartinFebruary 17, 2005 at 4:37 pm #126336Dave_Conway
The part you need isn’t inthe shop at the moment, I can easily add it though for you, let us have the model number and I’ll check it out for you 😀
February 17, 2005 at 8:47 pm #126337admin
The inner door trim doesnt saeem to have a full part number. I took it off and all it has is the Hoover logo and H2 -1 The actual front cover has a part number ofD37341-530 issue / MJ26529D H1. As I said initially, I only want whatever bit has the plastic clip that holds the door shut into the washer/dryer itself. Is that enough info or do you need more?
February 17, 2005 at 9:37 pm #126338Dave_Conway
Anonymous wrote:Is that enough info or do you need more?
More please, it’s the model number of the washing machine we’re after rather than the part number for the door.
The model should actaully be on the inner door frame, but it sounds like it’s either fallen off or been removed.
It will also be on the back somewhere and in the user manual.
February 18, 2005 at 12:44 am #126339Penguin45
P/no 09077165 – about £8 from memory. The model number is on a label around the door opening and will start “A8—“. It’s also on a label on the side of the right side of the machine and a rating plate on the bottom rear. However, the part number is 99.99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} likely to be correct.
Check, then contact spares@ukwhitegoods.com and it’ll get sorted out.
Penguin45.February 18, 2005 at 9:51 am #126340admin
Last one I promise!
I cant find anything begining with “A8” but in the place you mentioned on the door opening, there is a number – “WS 11574500002”. On the right hand side of the machine there is a shortened version of this number “WS 115-001. Do either of these sound like the right number?
February 18, 2005 at 11:02 am #126341Dave_Conway
Got the email thanks.
February 18, 2005 at 2:12 pm #126342Dave_Conway
The part is already in the shop@ 😆
http://shop.ukwhitegoods.co.uk/Washing+ … Frame.html
February 26, 2005 at 11:38 am #126343admin
can any one tell me which pipe it is that i need to take of to look for a blockage took the big black one of the drum and emptyed the water all over please help cheers wayne
February 26, 2005 at 2:37 pm #126344Martin
Anonymous wrote:can any one tell me which pipe it is that i need to take of to look for a blockage took the big black one of the drum and emptyed the water all over please help cheers wayne
Also check the pump itself is not blocked and is free to rotate!
April 13, 2005 at 7:02 pm #126345admin
Hi I’ve also just suffered the same problem. I have model number
A875470400374 on the machine. Can you please advise me if there’s a part of this?
Thanks very much.April 13, 2005 at 7:10 pm #126346Penguin45
I take you are after a drain pump?
http://shop.ukwhitegoods.co.uk/Washing+ … +Pump.html
will take you there.Before spending your money you have checked for blockages?
Penguin45. -
