Hoover spinner/TT belt
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Hoover spinner/TT belt
  • #33317
    Anyone know if Masterpart belt HV0853 is the small vee belt for the single spinner , the same one that fits the twin tub as well?
    wilf
    Re: Hoover spinner/TT belt
    spindryer and twintub belts were NOT the same. sorry cant remember the numbers
    wilf
    #238271
    aqualectric
    Qualtex VBT04 was the small ‘V’ belt for the spin can drive. Shows as obsolete, I’m afraid. 🙁
    Try your local bearing supplier – they supply sectional ‘V’ belt kits that you can connect together to suit the application. (often used to make up belts for lathes, compressors and milling machines). Worth a go, Jim!! 😉
    Hope that helps,
    Steve.
    (Happy New Year to you!! 😀 )
    #238272
    And to you also Steve,
    I will give that a try if all other avenues fail.
    petalpop
    connect say they have the genuine one in stock 5031680388381 £1
    or pattern blt103 £1.10
    didn`t think the genuine one was available let alone cheaper than pattern but hey thats connect for you
    #238274
    Actually managed to find one on a local market stall, rummaged under piles of junk for it. 8)
    jim.
