hi guys never come across one of these , big round twin element dryer , power going to one side of element , heats ok , tested element for continuity and all the tags have readings between each other , how can this be , i removed the wire connectors before testing , also there is a square white block on the back of the element housing with wires in and out to the element , a thermostat ? no power going to this either , also there is power coming from the timer but it never makes it to the end of the wire connected to this one is going to the element also , anyone have info on these thx
