Hoover switch to nickel coated heaters
Home Forums General Trade Forum Hoover switch to nickel coated heaters
  • #78605
    To ensure maximum durability and reliability over time especially with “hard” water, GIAS has decided to manage some new Water Heating Heaters with a protective galvanized surface treatment. The new “nickel plated” Water Heating Heaters are now automatically supplied by GIAS.
    Also as of Jan 2014 all nickel coated elements will be rated 240v and not 230v as they are at present. Bringing them more in line with UK standard main voltages.
    #406235
    timdowning
    Re: Hoover switch to nickel coated heaters
    Boo!
    #406236
    DrDill
    I thought uk standard voltage was within 6{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of 230 volts now, not 240.
    #406237
    Madmac
    timdowning wrote:Boo!
    Boo indeed, I like heater swaps, much easier than bearings as one slips steadily through middle age. Although the 2 year old Hvr I changed the element on last week had coin damage to be honest, pretty soft water around these parts.
    #406238
    stratfordgirl
    European mains voltage was harmonized to 230V in 1995 but in practice power distribution in the UK is still set up for 240V as it would be too costly to upgrade the network.
    #406239
    stratfordgirl wrote:European mains voltage was harmonized to 230V in 1995 but in practice power distribution in the UK is still set up for 240V as it would be too costly to upgrade the network.
    When using my Loop tester each day ( like most of us do eh?) the average mains voltage reading around west Berks and north Hampshire normally is 235 – 242v during off peak times. So it follows 240 rated heaters are a better choice I reckon.
    #406240
    DrDill
    I get as high as 265 volts down here, so many over head cables and transformers on posts!
