Hoover T/D HNV380-80 Drum Support Wheels
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover T/D HNV380-80 Drum Support Wheels
  • #55177
    Pigpen4
    Went to replace the drum support wheels on an HNV380-80 today, using the parts listed on both Connect and MasterPart – Hoover pt no 97920557.
    On opening up the machine, the ones in there are totally different.
    The supplied parts are solid plastic wheels, with a thick rubber outer, approx 62mm diameter overall, whereas the originals were bearings with a thin rubber coating around the outer race and only measured around 37mm diameter.
    The originals have “6202LUV CW” embossed on the bearing race cover.
    Anyone got any clues as to their part number identity, so I can replace them? (One of them is exceedingly wobbly!) Pleeeeease? 😕
    #322184
    helo_75
    03850295 is the correct number for the drum support wheels on that model
    #322185
    Pigpen4
    helo_75 wrote:03850295 is the correct number for the drum support wheels on that model
    Thanks, Helo75, but that just throws up the 97920557 big wheels on Connect and MasterPart, the latter listing it specifically as an “equivalent”.
    Not what is fitted, though!
    Might there have been a modification?
    #322186
    helo_75
    only on the later ones, but its the part number of gias tech site
    #322187
    helo_75
    but then , saying that, does it look like this?
    http://www.partmaster.co.uk/cgi-bin/pro … path=45784
    #322188
    Pigpen4
    Re: Hoover T/D HNV380-80 Drum Support Wheels
    Thanks, Helo75, that’s exactly the one, also available on Connect as Bearing wheel (5045173712959), now that you’ve identified it for me.
    Many thanks,
    Pigpen 🙂
