HOOVER T/D (TV 30 001)
  • #58223
    Galway
    HI ALL
    WAS AT THIS WITH A NO HEAT FAULT .THE ELEMENT HAD FAILED AND THE FILTER LIGHT WAS ON SO I REPLACED THE ELEMENT AND CLEANED THE FILTER AND DUCTS OF THE DRYER.NOW WHEN I START IT HEATS FOR A MIN OR SO AND THEN THE FILTER LIGHT COMES ON AGAIN.AM I FOR GETTING SOMETHING NECER HAD THIS PROBLEM BEFORE .
    THANKS
    NIALL
    #333781
    Re: HOOVER T/D (TV 30 001)
    its got to be an airfolw problem not enough air going through element to keep it cool. thats what happens when filter light comes on because filter is blocked
    ps dont use caps its the forums equivalent of shouting
    #333782
    allan73
    I’ve had the rear drum seal drop off & cause this problem on these.
    #333783
    try replacing front stat… inside the front filter housing…
    pn…..5031689259422 at connect…
    #333784
    Galway
    thanks guys
    sorry for using caps i didnt notice
