Re: Hoover TC65 Tumble Dryer
Thanks for your response.
Yes I found the other thermostat after much searching and tracing wires around. I joined the two connectors together with a piece of wire and tried again, but still no heat!!??
Would a fault on the timer control also affect the heater? I’m begining to think the problem must be elsewhere as the heater seems ok and bypassing the thermostats makes no difference?
I’m going to do a bit more investigating tomorrow, but any suggestions would be welcomed.
