This dryer totally dead. No indicator lights , motor action , nothing.
I know when you have to keep your finger on the start button that the small PCB is at fault (91201247) but can this part also cause machine to be dead or is something else likely to be causing this.
Customer insists power to dryer ok , mind you I`ve heard that before 😆 .
Any help/advice much appreciated.
Ive had a couple of mains filters go o/c on these or even bang keep one in stock now. relay (pcb) could also cause same (sod to get at the screws need to take off entire front watch out for all different size screws)
