hi guys,
hvr condensor dryer TC650 001 37616323
went to no heat problem.stat on top of element faulty,condensor blocked solid.
no worries so far.
replace element and clean condensor,sorted(i thought)
put it through a short test run,electrical safety,function test etc.
the dryer drum does not stop when the door is opened,the heater stays on when the timer has finished and the stop position for the timer is at 4 o clock instead of at the top i.e. 12 o clock.this is in a pub and get’s load of stick.
do you thing the timer contacts are “fused” together and not switching as they should,or do you think someone has turned timer the wrong direction and damaged it.
i’ve checked all the obvious,door microswitch,start relays etc.
the only thing i can come up with is the timer,has anyone come across this before?
cheers .
john
