Hoover tumble drier HDV6 part required
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover tumble drier HDV6 part required
  • #7464
    My HDV6 has stopped getting hot, I think it is the thermastat thats gone as there is mains to it and the heating element is has resistance across it.
    Do you guys have a part no? and where from?
    Also, Embarrassingly 😳 I have managed to break the front panel ‘Heat Setting’switch in the process (I just eased it out with the crow bar and pop!).
    Any numbers for that too? and where is the best place for parts.?
    Many thanks, Mark T
    #123512
    Dave_Conway
    Re: Hoover tumble drier HDV6 part required
    The heater is in the shop@ here Mark:
    http://shop.ukwhitegoods.co.uk/Tumble+D … ement.html
    There’s two switches on the front but on the diagram it doesn’t indicate which on is which 🙄 one is normally closed contacts, the other normally open, if you can let me know which one you need I’ll get back to you on that 😀
    #123513
    Thanks for heater info I will order with switch if poss:
    The switch on the front panel has zero resistance in its resting postion, going to high resistance when activated. (is that open or closed, sorry its along time since I did this sort of thing for living.
    Best regards M
    #123514
    Dave_Conway
    Normally closed then 😀
    That’s part number 28225024 which is £3.97 inc VAT.
    This would be a special order from GIAS (Hoover/Candy group) which I can do for you, normally 7-10 working days.
    If you want to order them both, go to the shop and order the heater and leave a note indicating that you would like the switch ordered and authorising that we may charge the extra £3.97 to your credit card (it’s a legal thing ;))
    I get and deal with all the orders so I’ll remember it.
    Hope this helps.
    #123515
    Thanks for a very painless operation. Now where is that crow bar…?
    #123516
    Dave_Conway
    Order recieved thankyou 😀
    Parts wil go as soon as the switch gets here, should be with you by next w/e hopefully.
