Hoover Tumble Drier HDV6UK Relay Board?
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Hoover Tumble Drier HDV6UK Relay Board?
  • #17990
    laurenceuk
    When the On button is pressed the relay contacts `rattle` and won`t stay engaged, drum stops rotating when finger removed from switch.
    Q1. The customer says the `on/off` switch won`t stay in but (I don`t see these that often) I suspect the `on/off` switch is just a push and release start switch. Am I right? If so the labelling of the start switch on the panel is misleading as it reads `on/off`
    Q2. I also suspect that the relay is the problem – again, am I right?
    If so can someone give the part number for the relay board please.
    Laurence
    Serial No 3110023
    #177310
    Re: Hoover Tumble Drier HDV6UK Relay Board?
    It’s a non-latching switch and it’s always the relay board.
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=347
    laurenceuk
    Thanks Chris
