Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hoover tumble dryer board configuration?
- This topic has 10 replies, 5 voices, and was last updated 16 years, 4 months ago by
snig.
November 27, 2009 at 5:55 pm #50509
snig
ParticipantCalled to hoover HNC270 dryer with no heat. establise heater circuit ok and assume pcb fault. Called back with new board but can’t get it to start. Display lights up but no action. Does anyone know if these boards need to be configured, and if so, how!!!
November 27, 2009 at 6:51 pm #305055Penguin45
ParticipantRe: Hoover tumble dryer board configuration?
You should have 40001754 – pcb (programmed).
November 27, 2009 at 7:01 pm #305056snig
Yeah, thats what i fitted. Must be a faulty board then ?
November 27, 2009 at 7:26 pm #305057pegasusk7
Although you may have ordered the correct programmed version of the board it may not actually be programmed, believe it or not! That happened to me a couple of weeks back.
Phil
November 28, 2009 at 9:52 am #305058snig
If it came unprogrammed, how did you get over it. Did you send it back or can it be programmed on site ?
Paul
November 28, 2009 at 10:07 am #305059pegasusk7
Have PM’d you, Paul.
Phil
December 17, 2009 at 5:44 pm #305060snig
thanks to peagasus for your reply. Called today with another board, still no joy. Lights come on and cycle thru a sequence when you push start button but nothing else. Refit original board and everything works ( except heater, original fault) Seems quite obvious this board needs configuring but no info or way to do it ! Very annoying if these boards are sold as configured !. Anyone else have any ideas ?
December 17, 2009 at 6:24 pm #305061Martin
snig wrote:Anyone else have any ideas ?
Can we just rewind as to the exact symptoms? 😕
It doesn’t heat (got that bit) but if it doesn’t start (i.e dead) then nowt is occurin’ anyway. 😕
So, hows the door microswitch doing?(highly suspect) Selector switch? The Front stat? Float stat?
I’m not thinking circuit board at this point TBH.
December 17, 2009 at 7:48 pm #305062snig
Sorry if i’ve confused the issue. Original fault; machine starts and turns but no heat. Traced to no supply from pcb. Fitted new board, NOW won’t do anything except sequence thru various led displays each time you press start button ?( not related to programme so assuming conf. code or similar ). Refit original board, machine reverts to original fault.
December 17, 2009 at 7:51 pm #305063BobHope
the pcb should be configered but you do get the odd one slip through that is not, if you dont have access to the hoover memloader then its another pcb im afriad.
Bob.
December 17, 2009 at 8:43 pm #305064snig
I was afraid of that. This was the second board, can’t afford to lose any more money on this job !
