chris sent me a wiring diag but unfortunatly the diag was for a dryer with an ntc and mine has two standard stats mounted at the front on the filter box if you have vanother diag i would be grateful
there is a green wire coming off the pcb connector with a .25 insulated spade on the end that is not connected i am reluctant to plug it on in case it blows the new pcb does anyone know if this should be unconnected or not
