Home › Forums › Public Support Forums › Spare Parts Help › Hoover Tumble Dryer latch receiver
- This topic has 11 replies, 3 voices, and was last updated 17 years, 10 months ago by
mark1892.
June 14, 2008 at 3:13 pm #37390
mark1892
ParticipantA relative needs a new latch receiver for a Hoover New Wave tumble dryer D6986. been told the item is now obsolete but they have just paid 40 quid for a new door so would really like to get hold of one.
thanks in advance if anyone can help. i will get the serial and model no now and post them up.
June 14, 2008 at 3:20 pm #254724mark1892
ParticipantRe: Hoover latch receiver
model no.37601432
serial no.D698671100144
June 14, 2008 at 3:58 pm #254725Phidom
ParticipantRe: Hoover Tumble Dryer latch receiver
Part Number is 09088436. Best thing to do is make an inquiry with the spares shop at this site as they have access to various suppliers.
June 16, 2008 at 12:10 pm #254726mark1892
tried that mate thanx but no luck. the door closes fine but the prongs on the back which the switch clamp onto have broken off. having just paid 40 quid for the door, i am tempted to just bypass the switch or tape the plunger on the switch so it will work. i know its probs not a recommended fix but anything is better than scrapping it just for this.
June 16, 2008 at 12:33 pm #254727Phidom
The latch receiver is just a plastic plate that screws on the outside of the cabinet, are you sure that’s the part you mean?
June 16, 2008 at 11:29 pm #254728mark1892
yes mate it screws on to the cabinet but then the switch that the door pushes on, screws to it on the inside. to make it work when you shut the door.
June 17, 2008 at 7:11 am #254729Phidom
I’ve probably got a secondhand one but I can’t find any photos of the part so would be unable to identify the correct one.
June 17, 2008 at 9:19 am #254730mark1892
phidom, thanks for your help mate. whereabouts in the north east are you? i have managed to screw the switch onto the back of the latch receiver and is working ok at the moment but if you had one it would be better if i fitted that. i will take a pic of it next time im over there and post on here to see if you have a match.
regards
markJune 17, 2008 at 8:06 pm #254731Phidom
OK, I’m near Buckie.
June 19, 2008 at 7:47 am #254732sheer1delight
Is this the same item as fits softwave machine. Microswitch fits on two posts of assembly which in turn bolts to front part of latch that is located on front of machine?
I could forward secondhand assembly.
Even better. Why not visit your local council/ scrapyard and buy a whole machine for a few quid? There is a chance you will find one there!
Regards
June 19, 2008 at 8:02 am #254733sheer1delight
Ooops sorry. I thought this was a washer dryer.you were describing- my fault. Do you know if tumble dryer interlock is similar to that of washer or washer/dryer.
regards
June 26, 2008 at 12:04 am #254734mark1892
sheer1delight wrote:Is this the same item as fits softwave machine. Microswitch fits on two posts of assembly which in turn bolts to front part of latch that is located on front of machine?
Regards
already tried the recycle place. none that type. your description sounds right and it is off a softwave dryer, have you a pic??
