Hoover Tumble Dryer – Model TV30
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover Tumble Dryer – Model TV30
  • #22373
    rapalla
    Model – Hoover TV30-001
    Problem – when ‘start’ button is pushed the drum starts to roll but there is a loud buzzing coming from the vicinity of the timer. When I release the ‘start’ button the drum stops rolling and the buzzing stops. Sometimes holding the start button in for some seconds causes the buzzing to stop and the drum to rotate without further button holding.
    To me it sounds like a relay or connector problem.
    Inspection under the lid shows a small relay panel adjacent to the timer. Is this where my problem could lie? I have made sure that all the connectors to the timer and relay panel are secure (with the power switched off of course) but the problem persists. I cannot determine whether the sound is coming from this relay panel or the adjacent timer as they are very close together.
    When the drier kicks in everything works as it should until such time as its finished its cycle or the door opened.
    Any help in confirming which is the defective component would be appreciated
    #194702
    Re: Hoover Tumble Dryer – Model TV30
    rapalla wrote:Inspection under the lid shows a small relay panel adjacent to the timer. Is this where my problem could lie?
    Yes! :tup:
    #194703
    You can get one here:
    http://shop.ukwhitegoods.co.uk/product_ … cts_id=347
    rapalla
    Thanks guys for confirming my suspicions. I have ordered the PCB from UKwhitegoods and look forward to getting my tumble dryer repaired and back in operation.
    #194705
    Stay safe, power off when fitting…….
    Good luck,
    rapalla
    I ordered the replacement card through UKwhitegoods and was pleased by the fast delivery. Got the relay card fitted yesterday…. what a pig of a job though! The card was secured by 2 self tapping screws which could only be accessed by taking off the whole front of the machine. What should have been a half hour job at most, took several hours to complete. But hey, its working fine now. Many thanks to the guys who responded to my initial query. 😀
