Hoover tumble dryer switch double pole n/o rewiring
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hoover tumble dryer switch double pole n/o rewiring
  • #95519
    wheelhouse20
    i need some help in connecting the wires to the power switch for my HOOVER TUMBLE DRYER SWITCH DOUBLE POLE N/O for HNC382T Hoover 8Kg Tumble Dryer
    thanks
    #460591
    have no diagrams but should be able to work it out
    how many wires have you got and what colours
    a pic might help
    #460592
    wheelhouse20
    here is the picture of the wires.
    https://photos.app.goo.gl/nquYFeHWw87GoQuQ9
    #460593
    that should be fairly easy try this connect 2 brown wires on one side of the switch and the two blues on the other. as for the different colour ends i would put the 2 whites at the front and the 2 blacks at the rear
    wheelhouse20
    electrofix wrote: that should be fairly easy try this connect 2 brown wires on one side of the switch and the two blues on the other. as for the different colour ends i would put the 2 whites at the front and the 2 blacks at the rear
    Does it matter where the cables go to ? (motherboard,motor,suppressor)
    #460595
    not really as long as colours don’t mix. I would put the pair from the suppressor on the same position on the switch but it does not matter if its the front or the rear pair
