Tell us what you need
Good Morning , just wondered if anyone could help . I was asked to look at a friends dryer. Fault is that it stops after around 5- 10 mins. It does not have a digital display , just 6 red leds which all flash together evenly after shut down. It will start again if its turned off and back on. Tank is empty, filters clean , etc.
I have limited knowledge of electronics ( Retired Car Mechanic) , so i would appreciate from your experience the MOST LIKELY thing that is wrong with this model. So, if its a thermostat issue , we will risk buying items one by one in the hope it works . I know its not the best approach but its preferred in this case
Thank You
Regards
Paul James
