Hoover Tumble Dryer VHV680F-80 no heat
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover Tumble Dryer VHV680F-80 no heat
  • #72217
    Bernie
    When I first started the machine the heater did start to warm up but that was it, then it all went cold
    Have checked the heater, and the toc all ok just to make sure the stat on the heater was ok I fitted a new heater assembly this was still the same no heat. Is there another stat some ware on this machine, if so where? Or am I looking at the PCB
    Any help and suggestions much appreciated
    Bernie
    #383895
    Criscold
    Re: Hoover Tumble Dryer VHV680F-80 no heat
    There is an NTC on the front below door that could be at fault, looking at diagram I think this would be the only thing that could cause this other than the board.
    Colin
    #383896
    Bernie
    Thanks for the reply Chris
    I looked on Connections site and it has a Thermal Limiter part no. 5045171534522 would that be the part?
    #383897
    Criscold
    Yes looks like the correct part – HVR40003258
    Colin
    #383898
    Bernie
    Thanks again
    Bernie
