Hoover TV630 001 advice please
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover TV630 001 advice please
  • #11752
    Davidjames
    Our Hoover Tumble Dryer TV630 has a problem. No heat from the element AND the “Filter Care” indicator won’t extinguish. Have fully cleaned out the filter, plus all accessible parts of the ventilation mechanism, but no luck. I don’t know my chicken from my egg : Is the heater not working because the sensor that triggers the filter care indicator also prevents the heater element(s) getting power, or if the element(s) are faulty – would that somehow trigger the filter care indicator ??
    As you will know, the element and overheat thermostat are very easy to get at, but there seems to be a second sensor inside the filter casing which looks like it might be difficult to access. Any advice gratefully received – I’m capable of changing the element (which seems to be supplied as a whole unit complete with o/h stat, but I’m not quite so sure about total dismantling of the machine.
    #146537
    Re: Hoover TV630 001 advice please
    Integral safety stat has failed. This:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=292
    is what you want.
    Power off, of course.
