Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hoover TV630 – Thermal Fuse Replacement Part
- This topic has 9 replies, 7 voices, and was last updated 19 years, 1 month ago by
roadhouse1387.
February 21, 2007 at 8:09 pm #25259
roadhouse1387
ParticipantHI,
Well, here i am again, the thermal fuse on my tv630 has blown again. The dryer is about 5 years old and this is the 3rd time its gone. I’m fed up paying £30-£40 for replacement heaters when the fuse is only about 50p.
ok, so i have a background in electronics so i intend to replace the fuse with one of these parts I have found on Farnells web site….
http://uk.farnell.com/jsp/endecaSearch/ … 138647&N=0
physically, its almost a direct replacement for the microtemp device fitted as standard.
I have read conflicting advice re the opening temperature of the thermal fuse. Some posts put it at 152c whilst the microtemp unit itself is maked 206c.
Which is correct 152 or 206 ?
As I understand it the fuse will ‘blow’ at the indicated temperature, is this correct ? secondly, the replacement part from farnell, which is rated at 15a and ‘blows’ at 190c should be as near as damn it, a suitable replacement. ?
Thanks for the help
ShaunFebruary 21, 2007 at 8:38 pm #205090Penguin45
ParticipantRe: Hoover TV630 – Thermal Fuse Replacement Part
Don’t know the rating off the top of my head, but it is usually printed on the fuse – you’ll need a magnifying glass though.
Would make more sense to work out why it keeps failing……? Manic overloading, opening the door with the heater on, crushed vent hose, blocked wall vent, loose fan, lack of ventilation can all cause this.
Penguin45February 21, 2007 at 8:59 pm #205091roadhouse1387
Thanks for that Penguin…
Actually we do most of thoes things…. 😳 ..and the hose is crushed 😳 😳
The existing fuse is marked ‘tf 206c’ so i guess it blows at 206c ?
I think the 190c replacement fuse will work fine, should blow a little earlier than the 206c one but rather that than fit one with a larger rating. whats your view ?
(naturally, replace the hose first)
Cheers
ShaunFebruary 21, 2007 at 9:02 pm #205092Penguin45
206c it is then. Like for like if you can, otherwise go lower, never higher…..
February 21, 2007 at 9:38 pm #205093roadhouse1387
Will do,
I expect it will be ok, but i will post here if problematic, for the benefit of others.
Thanks for the advice Penguin
Cheers
ShaunSeptember 18, 2009 at 7:20 am #205094vofn
I can verify that this works! I was going to have to buy a complete heater element for my hoover dryer costing £49.99 + pp but after reading this I bought a fuse for 98p and hey presto! it all works fine
September 18, 2009 at 7:43 am #205095o_ptic
Yes, I’ve used the same fuse before – the rating is a 206C however I’ve always replaced with a 192C part.
As penguin said, find the concern first before replacing again….unless you have a trigger happy Wife who likes to beat the timer and open the door mid cycle?😀
November 2, 2011 at 1:50 pm #205096johnny3167
hi all had a similar problem with hoover hnc 175 80 , managed to get hold of original thermal link from ebay. heres the link.
http://www.ebay.co.uk/itm/140630431958? … 1555.l2649May 8, 2012 at 6:59 am #205097andyjohnfisher
I know this is an old thread but it still seems to be the one that Google throws up on the subject. After much searching it turns out the part is readily available from Conrad at…
April 28, 2013 at 12:41 pm #205098daddysnow
ParticipantHoover TV30 Thermal Fuse
andyjohnfisher wrote:I know this is an old thread but it still seems to be the one that Google throws up on the subject. After much searching it turns out the part is readily available from Conrad at…
Hi all
Thanks to this user!!
I was searching everywhere for this part with no luck.
Looked like it was going to be a complete heater unit.
The item from conrads looks the same part for the TV30 (i know there are a couple of models).
Thanks Again
Adam -
