The thermal fuse on my TV630 dryer has blown which I only discovered after reading all the previous posts concerning problems with this tumble dryer regarding no heat/ filtercare light, etc. I have removed the thermal fuse to see the markings on the body of the fuse (microscopic indeed!) which are as follows :-
MICROTEMP
KLHBDD
G5A01
TF 216C
The markings aren’t crystal clear, but the one that concerns me is the temperature rating which would seem to suggest it operates up to 216 degrees C. Surely the unit would be well and truly ablaze by the time it reached this temperature. Has anybody else got a blown fuse to hand to verify these markings/confirm that this is the correct rating?. These single use/non-self resetting thermal fuses can be sourced though RS (approx. 50p each) but there are a host of temperature ratings from 73C to 240C. Thanks for taking the time to read this post.
Cheers.
