Hoover VHC 381/1 -80
  • #89019
    chezzi
    Hi, we need to replace the door lock coupler on the above machine, (the part on the machine itself, not the part on the door), can anyone please tell us how to get this part out of the machine and replaced? we have the new part ready to go but just cant work out how to get it out?
    This is the part we have that needs replacing:
    https://shop.ukwhitegoods.co.uk/tumble-dryer-door-catch
    Many thanks for any help.
    #440074
    timdowning
    Re: Hoover VHC 381/1 -80
    The top lid needs to come off.
    Then fascia.
    Then door gasket.
    The lower plastic panel that hides the condenser.
    Then front panel can be unscrewed.
    #440075
    kaibart
    Three 7mm screws holding the lid on at the back then 2 screws holding the facia on then the door and the door seal needs to come off plus screws around where the door seal, may be 2 screw holding the front panel at the top as well and there are 2 screws holding the front panel on from the bottom one near where you pull out the condenser and one the opposite end 2 wire on the door lock doesn’t matter what way around you put them
