Hoover VHC 381 C/T/Dryer stopping
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover VHC 381 C/T/Dryer stopping
  • #65119
    Customer reported that it stops dead after a few minutes, sounded like a common relay fault but this one has a large PCB control unit.
    Set it to tumble and it ran perfectly for a good while, stopped to do the short reverse and then cut out after a couple of seconds.
    The start light on the front was flashing, I pressed ‘Start’ and away it went again in the original direction and tumbled for the full duration until it came to reverse and did the same thing again.
    Also noticed quite a bit of condensation running down the door glass. 😕
    An abomination of a machine TBH, any pointers as to the cause of this problem?
    loopey
    Re: Hoover VHC 381 C/T/Dryer stopping
    An abomination of a machine TBH YES . full strip down untill you get to the resavoir in the condeser unit were the pump should be , iff its got one or just a float with a micro switch ? it will be fluffed up to death.clean it out.
    water not getting to lower tank , also check for fluff in the neck of the water tank , hth phil
    edit thats why condensation running down the door glass it carnt get out . lol
    #359197
    No pump on this one, water container in the base.
    Customer has decided to bin it, motor was very noisy so probably for the best.
