Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Hoover VHC 381 cutting out
- This topic has 11 replies, 7 voices, and was last updated 12 years, 9 months ago by
Marymary.
June 25, 2013 at 8:30 am #75984
Marymary
ParticipantMy condenser dryer, starts its programme, runs hot for about 10mins and then stops, it can be restarted if I switch it off then press start but will cut out again. All filters are clean and if I try to press start before switching it off, I can hear a kind of clicking noise by the pcb. What needs replacing the heater element with thermo cut outs or the pcb? Thanks
June 25, 2013 at 11:56 am #396857kwatt
KeymasterRe: Hoover VHC 381 cutting out
Probably the heater but the only way to be sure is to test it with a meter. It sounds as if it’s overheating and cutting out which would indicate a thermostat fault but, on this tumble dryer, the thermostats sadly come with the heater complete.
The part is here if you need it:
http://shop.ukwhitegoods.co.uk/40004316 … yer-heater
I don’t think we’ve ever been asked for a control module so I’m guessing that it’s a low failure rate on those.
HTH
June 25, 2013 at 1:37 pm #396858Marymary
ParticipantRe: Hoover VHC 381 cutting out
Thank you, will give the heater a try
June 25, 2013 at 2:03 pm #396859iadom
ModeratorRe: Hoover VHC 381 cutting out
The small pcb/relay is a known point of failure on these as well, also a lot cheaper than a heater.;) Heater cutting out shouldn’t stop everything. 😉
Sent from my iPad using Tapatalk HDJune 25, 2013 at 2:11 pm #396860kwatt
I did not know that. You learn something every day.
I’ve asked Dave to add it just in case.
June 25, 2013 at 2:15 pm #396861iadom
The most common Hoover/Candy relay is already in the shop, not sure if it fits that model though?
June 25, 2013 at 2:30 pm #396862Dave_Conway
That model doesn’t have seperate a relay fitted 😉
June 25, 2013 at 2:31 pm #396863iadom
That explains why I couldn’t find it on GIAS. :clown:
June 25, 2013 at 3:05 pm #396864Martin
Gotta look out for the error code on these. The OP didn’t mention whether the LED’s are flashing when this fault occurs?
Time to count the flashes Marymary to figure out how contrary your dryer is? 😉 😀
June 27, 2013 at 9:22 am #396865Marymary
Hi thank you for your replies, so heater replaced and no change, there are no flashing lights it just returns to the start light. What next I wonder??
August 19, 2016 at 10:17 am #396866roduk
I have this problem too. Exactly as described, the dryer cuts out after a few minutes. It’s heating and pressing start just results in a click. Turning off and on resets but the behaviour is the same. It does run on the Refresh programme though.
Was a solution found?August 20, 2016 at 8:22 pm #396867admin
PCB required
Bryan
