no turny, unless you help the drum out…
can anyone confirm for me if that exact model has a 8uf on the motor, or whether it just had the relay built onto the pcb?
Would have stripped it down, but teh way the utility room was installed around/over it, makes it v difficult to get out and work on, so wasnt gonna dismantle utility room and strip it down to find out theres no cap on the motor 🙂 I did manage to get the lid undone and slid it back far enough to hear a buzz coming from the pcb, and also the start/pause wont pause once selected, even if once youve helped the drum on to turn ok, it still wont pause. so thats obvs screwed 😕
Connect and qtx are useless as neither lists a motor, or cap, so i cant see if its got one on the pic, and connects mediator only seems to be showing half the tech diagrams for it too.
s/n: 31100282-085035880
