Re: Hoover VHC391 Capacitor replacement
** Disconnect from the mains **
Unscrew screws at the top of the rear of the dryer which allows the top panel of the dryer to slide backwards out.
To take off the front of the dryer, unscrew the 4 screws at the top of the inside front console.
Lay the dryer onto it’s back and open the dryer door there are 4 screws on one side and two on the other. Leaving the bottom screw on each hinge, unscrew the top hinge screws as well as the two screws on the other side.
Remove the seal from around the door.
Then finally there are 3 more screws on the under panel to unscrew. This allows the front panel to be moved enough to see inside the dryer.
As far as I know this machine does not have a capacitor.
Re-assemble the dryer by going back trough the steps in reverse.
George
