Hoover VHC681B
  • #89899
    Levenfields
    Need to fit felt seal front duct. what do I have to do to access felt ridge? :eeek:
    #442942
    kaibart
    Re: Hoover VHC681B
    Hi his job means dismantling the front of the dryer I would call someone in to do it unless you have done something like this before.
    #442943
    Levenfields
    Re: Hoover VHC681B
    I can do it if you advise me where to take off front of machine
    #442944
    kaibart
    Re: Hoover VHC681B
    Ok safety 1st unplug machine remove lid 3 screws at the back and the plastic sides then there are 2 screws holding the console on,then remove door then there are 4 screws holding the front panel on,and 1 each end at the bottom of the front panel then you have 4 7mm screws to remove front panel there are 2 wires on the door lock of front panel to and then your where you need to be, I still advise you to have someone who knows how to do this as it a big job,and I wount be able to help you further regards kai
    #442945
    Levenfields
    Re: Hoover VHC681B
    Thank you will have a possible look at this.
