Hoover VHD 814-80 door security light problem
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover VHD 814-80 door security light problem
  • #73184
    baxdidub
    I have a Hoover VHD 814-80 washing machine. I was getting the flashing door security light every time I tried to start a wash. I initially thought it may have been the door interlock but I have shorted the interlock switch out (linked out the 240v loop) and the flashing door security light still continues to flash. The 3 wires from thge door interlock then feed into the programmable module. Is this the likely problem before I order a new one or am I missing something obvious????? Please help. Regards and a merry Xmas.
    #386666
    Re: Hoover VHD 814-80 door security light problem
    Replace the door interlock….though you may have stuffed the PCB by your over zealous shorting out and a close inspection of the PCB is recommended.
    #386667
    baxdidub
    The interlock switch is working ok, is there any way of testing the programmable module??
    #386668
    Nope
    Bryan
    #386669
    baxdidub wrote:The interlock switch is working ok,
    Are you sure?…….I don’t think so my friend. :rolls:
    #386670
    helo_75
    ill save u some massive expense
    the motor will have failed and blown the board… im always doing that repair
    if you look at the board, across the top edge u will see a single blown track
    you could try soldering it, but if the motors screwed, it will blow again
