Hoover VHD 8142 wrong cycles
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover VHD 8142 wrong cycles
  • #49406
    leeh
    I’m new to the forum, just a question regarding my Hoover VHD 8142 washing machine, less than 12 months old. The machine has recently started acting erratically! it does not appear to be washing on the selected cycles. i.e when i set the short 29 minute programe, it washes for well over an hour, at first i thought it was just my imagination, but i have since timed it, and its not right. Shortly after purchasing the machine, we had to call out an engineer, due to it not draining/rinsing properly, this was apparantly due to not having a sufficient load to enter the spin cycle, i rarely wash single garments because of this now, but when the engineer came he pressed a few buttons simultaneously to reset the machine’s software i think?! does anyone know this procedure, and if so do, they think it will solve my problem, because i like the machine, and it washes very efficiently. Thanks in advance for your help. Kind regards Lee H. 🙂
    #299812
    suedehead1
    Re: Hoover VHD 8142 wrong cycles
    the preselector timer is faulty its not resettable no amount of button pressing will fix it call hoover,
    when you set it to 29 mins the selector is telling the machine you have selected a different program, it needs a new part, dont touch it or you can invalidate your warranty.
    #299813
    leeh
    Thanks!! I’ll get onto an engineer 😀 by the way is this a common fault? pretty shoddy considering how long we’ve had it, needing new parts within 12 month!!
    #299814
    suedehead1
    no normally due to turning the selector the wrong way
    #299815
    helo_75
    roflmao!!! so why make the timer so itll go both ways?
    easy fix, lost count of how many ive changed
    #299816
    suedehead1
    why fix it yourself when its under guarantee?
    never had to change one and i am an authorised hoover agent.
    #299817
    helo_75
    ive changed hundreds.. and im a comet engineer
    maybe theyre all being sold through comet then
    #299818
    Higher-water-level
    I thought you could turn a solid state timer either way, its the mechanical ones that are clockwise only, I had a Hotpoint (WF530T) you could turn it in either direction, the manual backed that up. But my Bosch WFF2000 with a mechanical timer is clockwise only, it even has a device so it is impossible to turn it the other way.
    Oliver.
    #299819
    helo_75
    its a selector, not a timer
    it turns either way, its designed to
    #299820
    leeh
    Yes, it definitely turns both ways, and i have always been delicate with it, turning it lightly. I would have a do at fixing it myself if it’s easy? I’m not sure it is still under warranty? we’ve had it around 12 month. I don’t think i’ve broken it. Thanks for all the help 🙂
