I need the part number for the drum pulley please. It’s a plastic pulley with a splined centre boss. Also the part number for the belt as well please; it’s a 1225 J6. Nothing on Connections……:rolls:
Thanks for the part numbers, Jim. 😀
I have used a washer to pull the drum shaft through the pulley; but the boss is loose in the pulley. Not much, but enough to undo the bolt every 5 or so washes.
