Hoover VHD814280 wash machine
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover VHD814280 wash machine
  • #48134
    trotter
    problem on wool & 50 deg wash ONLY
    washes …when it comes to draining wash water, it drains completely & then the pump runs continuously until error code 3 is displayed.
    All other progs EXCLUDING woolens & 50 deg synthetics work okay
    Assumed board fault – replaced board ….SAME FAULT 😳
    HELP PLEASE! 🙂
    #295680
    smartin
    Re: Hoover VHD814280 wash machine
    siphoning ❓
    #295681
    trotter
    …..But ONLY on the two progs??
    #295682
    Certainly sounds like some problem that kicks in at higher water levels. So maybe it’s something to do with a pressure switch or the stuff that attaches to it.
    Mike.
    #295683
    trotter
    leavemetogetonwithit wrote:Certainly sounds like some problem that kicks in at higher water levels. So maybe it’s something to do with a pressure switch or the stuff that attaches to it.
    Mike.
    Mike I think you may be right with the pressure switch……I am going to try that and report back! (No holes in tubing etc) Thanks for your input guys
