Hoover VHD842-80
  • #53147
    United
    Hi, got a Hoover VHD842-80 washer serial 31002589 0829. Unit will fill, wash, heat and then drain, but then just keeps pumping and then three flashes on display indicating pump time out. It obviously thinks there is still water in unit, but is empty and pressure switch has de activated. Is this a circuit board problem, or am I missing something.Many Thanks
    #314576
    helo_75
    oh i love these machines
    can u be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure the pressure switch has deactivated?
    #314577
    United
    Re: Hoover VHD842-80
    Heard the click from switch when draining down, and made no difference when removed pressure hose from switch. Thanks
    #314578
    helo_75
    theres a memo…..
    heaters a problem for some, not all#
    #314579
    United
    thanks, it did heat the water, but I will double check anyway. Thanks for your help.
