Hoover VHD844DB80 stuck in fault mode
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover VHD844DB80 stuck in fault mode
  • #73777
    nelson
    I was at this one today, the machine would not start a program and when the start button was pressed the door security led flashed.
    I didn’t have the fault code list to hand so did some manual checks and found the brushes were worn out, I replaced the brushes and tried the machine but still no action other than the door security led flashing.
    I am assuming that the machine has gone into fault mode and needs to be reset, but I don’t know how to reset it.
    I tried pressing and holding the start button but this just caused some of the option leds to flash, 1,2 and 5.
    Can anyone shed some light on this for me.
    Cheers
    #388762
    Re: Hoover VHD844DB80 stuck in fault mode
    I’m thinking that the door interlock is the problem…..did you notice if the door actually locked?
    #388763
    nelson
    Actually Martin, you could well be right, the door did not lock but the door security led started to flash immediately on pressing the start button, which made me assume it was a fault elsewhere.
    I think I’ll get a door lock and try that.
    #388764
    Good plan….I like it! :tup:
