hoover vhd9143 zd80 motor fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hoover vhd9143 zd80 motor fault
  • #60074
    mikehha
    HI all
    I have a m/c that kicks the motor in to action for just a mille sec I have meggerd motor and its ok and there is no marks on the module, has anybody got any technical info. thanks mike
    #340649
    smartin
    Re: hoover vhd9143 zd80 motor fault
    loose tacho or broken magnet ?
    #340650
    loopey
    Inductor i goosed cut it out see iff that helps iff its a 3 fase motor wich i think it is ‘ hth
    phil
    The Inductor, as depicted in Picture 4, is a
    new typical component of the technology
    needed by the Three-Phase Motor.
    It is electrically connected in series to the line
    of the mains, immediately after the main
    ON/OFF switch.
    It basically carries out the job of an antiparasitic
    filter and is fitted to comply the
    approval’s specifications.
    In case it should become open circuited, one
    the thwo lines of the mains is opened too and
    the Washing Machine stops working. In such a
    case, it can be temporarily eliminated, by
    removing it and by connecting between them
    the two leads of the wiring. Nevertheless, as soon as possible a new spare inductor
    must be fitted onto the Machine, to comply with the original design and to prevent
    that some noise generated by the Three-Phase Motor, could affect the good performances
    by the Core Corntrol Board.
    #340651
    mikehha
    Thanks for the info boys but alas I think its the main core board anyone know the part no and if emw repair them .mike
    #340652
    loopey
    49018169
