Re: Hoover VHD9143D
mjhservices wrote:I suspect module?
I guess you’ve inspected/meggered the motor to confirm its OK have you Mark?
I wouldn’t jump too much to conclusions about suspecting the coreboard (Hoover’s name for module by the way.:wink:) without first checking everything else out especially the motor, heater, water level system and a full visual for surface damage to the coreboard itself. The next trick is to put the machine into TEST mode and see how each functions during that test sequence?
HTH? 🙂
