Hoover VHV180 blowing cold air
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hoover VHV180 blowing cold air
  • #88511
    sl75
    I have tested the 2 thermostats at the front, the thermostat, heating element and thermal fuse at the back with a multimeter and they all seem to be fine.
    Any ideas what could be causing the tumble drier to blow cold air? Not much left inside the machine to test? The timer switch?
    #438397
    Re: Hoover VHV180 blowing cold air
    can be the timer switch there is contact that turns the heat off 10 mins from the end
