Hoover VHV680C Not heating.
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hoover VHV680C Not heating.
  • #83372
    bigantkl
    Hi, new to the boards & in need of some help. We have a Hoover VHV680C Vented tumble dryer & it isn’t heating. We have replaced the thermal limited & have checked the other thermostats with a multimeter & they seem ok. It would appear there is no power getting to the element at all (I did a risky thing by bypassing the thermostat & it still didn’t heat up) Everything else works as it should, drum turns fine. What else could it be? Is it possible for half of a control board to go down?
    I will point out that I bought this secondhand & on inspection found that the original terminal block for the heating element have been removed & replaced with screw terminal blocks.
    Any help would be much appreciated.
    #422597
    Re: Hoover VHV680C Not heating.
    bigantkl wrote:I will point out that I bought this secondhand & on inspection found that the original terminal block for the heating element have been removed & replaced with screw terminal blocks.
    I expect that was the hint.
    Possibly the heater relay on the board, probably not worth repairing so ended up on Ebay or Gumtree as such things often do.
    bigantkl
    Is there a way to test the board for a faulty relay?
