hoover vhv680c vision 8kg vented dryer – all lights flashing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hoover vhv680c vision 8kg vented dryer – all lights flashing
  • #70281
    gandh1
    cust came in with burnt out module for this and wanted a replacement. ordered it in from connect mediator… so should be right (!)
    anyways cust dropped t/d off because now after 30 seconds of tumbling all lights start flashing and it aborts. had a peek about and cleared all the fluff out, and also replaced the “sensor” stat as we had one spare, still no luck, ps this is being tested on a timed dry too, not sensor drying 😉
    any advice guys??
    #377685
    gandh1
    Re: hoover vhv680c vision 8kg vented dryer – all lights flas
    *bump* HELP???!!!
    #377686
    suedehead1
    I have the same prolem, I replaced a module for a no heat fault,
    checked everything first.
    now it heats up for about a minute then all lights flash,
    #377687
    When all LED’s flash then that indicates that a ‘critical error’ has been detected by the PCB. The only resolve is to then go into the self test routine and find the error code that’s causing the error. Email me if you want the manual. 😉
    #377688
    Muv
    Hi martin, do you still have the manual for this dryer…got a customer who has tried replacing the board and heater himself…..need i say any more!!
    #377689
    Muv
    Anyone have a service manual for this machine please?
