Hoover VHV781c-80 Exhaust TOC
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover VHV781c-80 Exhaust TOC
  • #81540
    spiderpig
    Can anyone confirm if this TOC is rated at 85 degrees? It keeps going every couple of months, heater & stats already been changed, airways clear and customer cleans filter after every use. Starting to think the PCB may be at fault?
    #416944
    Criscold
    Re: Hoover VHV781c-80 Exhaust TOC
    Have you changed the NTC ?
    #416945
    Every few months apparently Colin.
    The heater box TOC is rated at 206°C by the way.
    #416946
    spiderpig
    Hi guys, talking about the TOC behind the front panel (down near the fluff filter). The heater assembly inc. stats have been changed. Cheers???
    #416947
    That’s an NTC and the one Colin (Criscold) may have been referring to? If you would like the service manual then email me.
    #416948
    spiderpig
    Thanks for that Martin, you’re a true gent. At least I know i’m ordering the correct parts now (item 443 thermal fuse)
    Cheers…..
    #416949
    :tup:
