hoover vhw654d
  • #88585
    wilf
    intermittent e04 fault shows worked fine for me until I put it back an plugged it back in the got e04 turned it off then back on then ok. fills to correct levels washes spins drains and no earth faults customer also reports door not opening when e045 shows. I have 41026150 pressure switch in stock does this fit? is it worth a try? any ideas ?
    thanks wilf
    #438658
    wilf
    Re: hoover vhw654d
    just for future ref it WAS the pcb so I will watch out for this again I did try the pressure switch first but to no effect.
    wilf
