Hoover vhw654d-80 dead
  • #79819
    pmb
    Hi when this machine is switched on the display partially lights for a split second and then nothing, no lights and no response pressing buttons. The user mentioned seeing e11(which is ntc/wiring trouble) before it died mid wash full of water. Everything seems ok so I am thinking the main pcb is at fault but could one of the ntc’s have caused this? Or am I barking up the wrong tree? Thanks for your help 🙂
    #410727
    suedehead1
    Re: Hoover vhw654d-80 dead
    Normally if you remove the oven you can see blown tracks.
    #410728
    pmb
    Thanks suede head for getting back to me, there was no visible damage to the PCB ( I assume you meant PCB as this is a washer dryer) the price of the PCB is surprisingly cheap and is already programmed so I will give that a go
    #410729
    timdowning
    Do check the top dryer sensor wiring. 2 thin red wires. They break and touch against the dryer body.
    #410730
    pmb
    Thanks Tim, I checked all the wiring between pcb and both sensors and it was fine
    #410731
    pmb
    Hi I fitted the new main pcb on this one today. The display occasionally comes on as it should when turned on but more often shows the small flicker then nothing as before. However now it has started a program (even when no display) which I can pause but doesn’t cancel when off is selected. I am next going to try a program selector switch unless anyone has a better idea?
