Hoover VHW654D-80 front fascia buttons.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover VHW654D-80 front fascia buttons.
  • #56146
    Washer dryer apparently. Just out of g’tee. Start button has gone in and doesn’t seem to be making contact to start machine. Bit of a long drag to get there so would like to go prepared. Anyone know what I’m likely to need?
    Two different fascias on pdf on mediator, one with 4 buttons, one with 6 (= W/D?)
    Mike.
    #326374
    helo_75
    accordig to the gias site, thees 5 buttons on that
    the pcb clips into a conainer which has the buttons on it, the containr p/no (accordin to gias) is 41028745
    it could just have pushed the pcb out of the container
    #326375
    helo_75
    Re: Hoover VHW654D-80 front fascia buttons.
    http://img835.imageshack.us/f/hoover.png/
    just to let u see for yerself[/list][/code]
    #326376
    Thanks for part no. Helo. Fascia looks a bit different from the one on Connect – everything in a different place. Suppose it’s not surprising when they change design every couple of weeks. :rolls:
    Mike.
    #326377
    we used to get a lot of these on the MFI versions, if its the same, the button assembly was only weakly clipped into the facia and was easy to push through especially by those who keep pressing ever harder waiting for the machine to start making noises regardless of the fact that there is a delay of a few seconds after the start button is pressed. it could easily be clipped back into place, but even better there was a stud and hole ready to accept a self tapper (or even 2 IIRC) that had obviously been dispensed with in some cost cutting exercise so fitting a couple of “back panel”style self tappers made a permenant repair.
    #326378
    eastlmark wrote: a self tapper (or even 2 IIRC) that had obviously been dispensed with in some cost cutting exercise
    😆 Oh, you cynics are unstoppable! 😆
    I’m quite sure there was a good reason for getting rid of the self tappers. Probably during research and development testing they were falling out and getting into the electronics where they fused everything. 😆
    Will take plenty of superglue, cable ties and a small drill as well as a selection of screws.
    Mike.
    #326379
    Hah! Another one’s just rung in with same fault! Holiday cottage right here in town. Model “H703” 😕 18 months old, and been repaired four times already apparently.
    Mike.
    #326380
    neilsukwg
    Its worth carrying a Hot Glue Gun for repairing these, makes a permenant repair.
    #326381
    Good tip, will remember that.
    Mike.
    #326382
    Did first one yesterday. Flimsy start pause actuator had partly broken so I welded it with solder iron tip and reassembled whole thing a bit more securely. Then gave customer a demonstration of exactly how little pressure was necessary to operate button.
    She then told me that the selector switch was a bit wonky too and needed to be tweaked sometimes to get it to programme. Always happy to learn these things after I’ve re-assembled everything :rolls: .
    Mike.
    BTW, Helo, diagram you referenced was the right one, thanks.
    #326383
    eastlmark wrote: easy to push through especially by those who keep pressing ever harder waiting for the machine to start making noises regardless of the fact that there is a delay of a few seconds after the start button is pressed.
    And that was absolutely spot on, too. 😀
    Mike.
