hoover vhw654d-80 w/d error code e11
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hoover vhw654d-80 w/d error code e11
  • #59579
    davebaron
    hi guys i have not seen this one,its only aprox 18 months old,it fills ok ,washes for a min or two then flashes up e11,it will empty the water heater is ok ,has any one got any ideas ,cheers d.
    #338780
    timdowning
    Re: hoover vhw654d-80 w/d error code e11
    did you check the wiring to the dryer ntc. give every wire a good old yank!
    #338781
    davebaron
    after looking at the known error codes,it looks like the dryer side,i will have a nother look and let you know ,cheers d
    #338782
    Nationalappliances
    Ive found this a few times! Loose connection to the NTC for the dryer 🙂
