Hoover vision HD VHD 9123 D
  • #66272
    Micky 32
    Error E 03 comes up which i believe is a drain fault but drains perfectly. Someone was at it before me and couldn’t solve it and they had even changed the pump. Of course this being a welded tub and a pressure chamber built in, i’m guessing it must be somewhat clogged that causes this? Is there anything else that causes that code? If a clogged chamber anyone successfully get it cleared somehow?
    Pressure switch seems ok and not sticking
    #363674
    Criscold
    Re: Hoover vision HD VHD 9123 D
    Earth fault on heater can cause this fault
    #363675
    ace
    Went to one about a month ago, same fault. Checked pump filter, sump hose for rubbish and the sink U bend connector. All fairly clean. Did a test wash, worked perfect. Got back home, customer phones to say its done it again, told them to switch it off, and leave it alone, don’t touch anything. Went back, very small load in machine, also they were using a liquid detergent, which they were just pouring in, no measuring. Therefore the pump was full of nearly neat detergent, which would foam up on first empty position. Advised customer to do full loads and use powder instead, had no call backs. Hope this helps, Martin.
