Hoover Vision VHD 814. Fault, flashes 8 times on timer delay
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover Vision VHD 814. Fault, flashes 8 times on timer delay
  • #59755
    smwaverider
    Hoover Vision VHD 814 problem. Won’t complete wash, long pauses between any action. Timer delay then flashes 8 times and repeats 8 times until I turn it off. Would be very grateful if you know what this error code means.
    Thanks, Steve
    #339512
    helo_75
    its a motor tacho fault
    tip the machine back, see if its dropped off the back of the motor first
    #339513
    smwaverider
    Re: Hoover Vision VHD 814. Fault, flashes 8 times on timer d
    Thanks so much for the answer. That came loose once before, so makes sense. Steve
    #339514
    Dazmufc
    I have the same problem i was told it was the carbon brushes, any help would be much appreciated,thanks
    #339515
    Oh dear, that username is fine by me but our friend helo_75 ( trotters fan ) may take exception to helping a Man U supporter. 😆
    The tacho coil may have come adrift from the end of the motor. Remove the mains plug, lean it back against a wall or the units and shine a torch onto the end of the motor. The tacho coil is the round disc with two thin wires going to it in the centre of the motor, they do sometimes come adrift.
    Or you may find it easier to just remove the motor from the machine to check the tacho coil, quite easy on these TBH.
    Up the Reds. 8)
    #339516
    Dazmufc
    oh well somebody has to support them eh. is the tacho coil the one that is next to the brushes, if so then mine is solid.
    #339517
    helo_75
    but is the magnet attatched?
    #339518
    Dazmufc
    As you can tell mate repairing my washer is entirely a new task, just trying to save a few quid as work is a bit quiet,and trust it to break down when the 2 year extra cover i had as not long ended. Anyway everything attached to the motor seems solid. where is the magnet? I’ve had a torch all round and inside the end of the motor i can’t see anything that has come adrift. Your knowledge would be appreciated. Oh and no offence against the trotters. 😉
    #339519
    helo_75
    the magnet screws on to the rear of the motor, inside the coil.. normally, if it had come off, then ud find it on the floor, its a small magnet, round, around the size of a 20p peice
    its not impossible the brushes have gone, but it does say in the manual its a tacho fault, be that o/c or the magnets broken/cracked or dropped off
    good luck
    #339520
    Dazmufc
    Thanks guys for your replies. I have taken off the motor and examined it there is no loose parts and nothing missing from the motor, so does this mean its the carbon brushes at fault
