HI, When I select any program the machine fills as normal, but then when it has filled it spins very quickly then stops then after about 5 mins it does the same thing. Then the speed light changes to 1200 and the timer saver light flashes for 8 times. Any help would be appreciated.
Penguin45 wrote:Tacho magnet and coil will have fallen off the end of the drive motor.
Power off and lean back for access.
I have exact same model and error code flashing. Have inspected motor, nothing loose or hanging off. what do Tacho magnet and coil look like? assume on opposite end shaft to drive pulley.
The Water Fill Phase was not completed within the designed limit time. Defective
Solenoid Valve, Pressostat, Water Fill Hose, Low Water Pressure in the network
and/or Wiring.
so take yer pick, from no water, syphoning to duff board
