I was looking for some advice. I’m getting an E3 fault and it’s not draining the water.
I cleaned the filter and found numerous objects. When I’ve removed it, something was stuck and a tiny piece of plastic has broken off the the filter (found between the 2 outer rims).
I’m still getting the e3 fault, I was wondering if it could be because of the broken part and should I get this replaced to eliminate it before seeking a professional?
Is there anything else I can do myself to fix the problem? And could you give me some instruction please.
Many Thanks,
Michael
