Hoover – VT 816D22/1-80 intermittent power
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover – VT 816D22/1-80 intermittent power
  • #89315
    twicknix
    This machine powers up, seems normal to start with then selected a program which in my case spin cycle. Pump activated, drum turned then went blank and powered back up and so forth. The display was flashing and the time remaining changed from something like 15 mins to 6 mins.
    It does seems like a module problem but which one? The facia one or the one at the bottom rear.
    Some pointers would be greatly appreciated.
    Thanks Matt
    #440992
    kaibart
    Re: Hoover – VT 816D22/1-80 intermittent power
    Put it into test mode if it goes through a test cycle the main pub module at the bottom of machine will be faulty if it doesn’t it will be the top board to put into test press and hold cold wash button and turn the dial to 60 cotton wait until all display and leads are lit release the cold wash button press all function buttons then start the leads for the buttons should go out when you have pressed start this will start the test cycle( make sure nothing in drum thou) hope this helps kai
